纳秒激光驱动,种子源驱动,mopa激光驱动,(ns laser,seed driver)
种子源驱动电路,针对mopa激光种子光源的驱动,可以做到10ns脉宽以下,重复频率1MHz以上,最大电流1A,无过冲,脉冲和恒流模式随意切换,CW模式输出电流0-0.5A与输入成线性可调,脉冲模式输出最大电流0-1A与输入成线性可调,带TEC温控,可适合各种波长的种子光源。可按要求定制
less than 10ns seed driver, designed for the use with laser-diodes in a butterfly-package.
the seed driver has got an internal TEC stage to drive typical TECs inside the butterfly package.
the driver has uart communicate with computer,it can help to monitor the driver and set parameters.
