当前位置:首页 / 案例库 / 无线调光器
无线调光器
★ 使用电压(Using voltage)AC 100V-240V  50/60Hz
★ 功耗(power dissipation):关断(turn-off):0W;  开通(turn-on):<1W
★ 调光器交流输入开关最大电流(Maximum current of AC input switch: 1A
★ 信号可以拐弯或穿墙,遥控距离(Wireless signal can turn or pass through walls, remote control distance:  5-50
★ 连线方便简单,不需要连接信号线,旋转即可无级调光,不频闪;一个调光器可以控制多个灯。(Convenient and simple connection, no need to connect signal wires, stepless dimming can be achieved by rotating, without flickering; One dimmer can control multiple lights)
★ 可以安装在H50H60H70等不同型号86型接线盒上,调光器尺寸86*86*33mm,内部高度15mm(It can be installed on different models of 86 type junction boxes such as H50, H60, H70, etc. The dimmer size is 86 * 86 * 33mm, and the internal height is 15mm)
评分:
客服电话
二维码
客服QQ
客服QQ:
1617942058
留言板
