当前位置:首页 / 案例库 / 无线充电接收模块
无线充电接收模块
 Integrated Wireless Power Supply Receiver
Solution
- High Efficiency Full Synchronous Rectifier
- Output Voltage Conditioning
- WPC Qi V1.2.4 Compliant communication
Control
- Single IC Required Between RX Coil and
Output
 WPC Qi V1.2.4 FOD Function
 Dynamic Rectifier VRECT
- Improve the Load Transient Response
- Optimize the dynamic efficiency for full load
 Rectifier Overvoltage Clamp (VOVP=15V)
 Support 20 V Maximum Input
 Over Temperature, Over Voltage and Over
Current Protection
 Open Drain LED Output Indication
 Multifunction NTC and Temperature Monitoring,
Charge Complete and Fault Host Control
 Compatible with Adapter and USB Input
Application
评分:
客服电话
二维码
客服QQ
客服QQ:
1617942058
留言板
